having bad luck asking questions in this forum...
I wonder if there is a better way or better visibility in this forum? All my questions go unanswered..
Is there a specified format or does it depend on the location?
Thanks..
Message 1 of 8
(3,590 Views)
Hi Palkin,
Dont be sad. If your messages are unanswered, then you just posted it on a weekend or Monday early morning.:smileywink: Just reply to the same thread asking for help again, you will get a reply soon or later.
Indeed this forum helps a lot. Count on me.  :smileyhappy:
Message 2 of 8
(3,583 Views)
Keep your posts small and try to post a small example vi.
Even if it is not working.
LabVIEW users are bored reading long text, describing what a vi must do Smiley Happy
Message 3 of 8
(3,579 Views)
Hi palkin,
"All my questions go unanswered.."
Wow, you made 4 posts so far. 4 posts in 3 threads (including this one). 2 of those threads got answers. One answer arrived just one hour after questioning - on an early Monday morning! What more do you want/expect?
You know this is a forum of enthusiastic people, ginving answers without any payment? We have to work and do our own stuff too!
Message Edited by GerdW on 11-09-2009 08:50 AM
Message 4 of 8
(3,566 Views)
thankyou guys....
Message 5 of 8
(3,509 Views)
Hi palkin,
marking it's own answer as solution feels, emh, not right - especially for an answer like "Thank you"...
Message 6 of 8
(3,505 Views)
State your problem in the simplest way possible.  Most problems are complicated, and the messy code surrounding the problem makes it overly complicated.
Most of the questions that go unanswered are either too ambiguous for anyone to know what the problem was, or the poster didn't take the time to post an isolated problem.
Also, don't mark your own post as the best answer.  That is not good netiquette.
Message 7 of 8
(3,490 Views)
GerdW wrote:
Hi palkin,
Hi GerdW,
Atlest this post had no solution involved. But check here. Solution was marked to their own reply though there was a real solution given.  :smileymad:
Message Edited by Vsh on 11-10-2009 12:05 AM
Message 8 of 8
(3,447 Views)
