hebrew looks gibberish
This seems such a common problem but I can't find any solution.
When typing text in Hebrew it looks like gibberish.
  1. I am using windows 10
  2. Labview 2015
  3. my system local is set to Hebrew
  4. I do not have this problem on any other program (used to have it in "Notepad", but after I have changes system local to Hebrew - it was solved)
  5. I do not see this behaviour on another computer with similar parameters (win10+LV2015+system local set to Hebrew)
  6. Several years ago I had a similar problem with labview 6. it was solved by a service pack released by NI - I hope this is not the case for the present...
(7,402 Views)
LabVIEW comes in a (limited) variety of language-specific Versions.  I haven't noted Hebrew among them -- you might contact your local NI Representative and ask about this -- surely they have an office in Israel ...
(7,378 Views)
Accepted by Hazkel
Thanks for the reply.
Apparently the story is repeating itself.
I have installed SP1 for Labview 2015 - and the problem was solved...
(7,376 Views)
Great -- mark your last Post as the Solution (you are the only one who can do that) so the next person with the same question can go right to the answer!
(7,373 Views)
