help hp instruments
Hi
I am new to labview (very)
and an trying to set it setup for a class, the students will be using the following instruments [hp34401a, hp33120a, hp53131a and hp54600a] .
The GPIB seems to be setup OK and labview has drivers for these instruments . I can find them and install the drivers OK and this is where the
trouble begins. the 34401a dose work but crashes every chance it gets.
The 33120 will not run at all the GPIB dose not like the string it returns ? the 54600a scope has two channels but not in labview and my attempts to
set it to channel two have not been successful.
I cant seem to figure out how to see the strings coming from and going to then instruments.
If any one could provide some over view about setting up these instru
ments it would be very helpful
Ben Barron babarron@home.com
Message 1 of 1
(7,125 Views)
