help please ont this VI
hi guys
I posted this question berore but I could not find the answer. I attached a jpeg file and I could not find what it is and how to use one spot that is bordered by red frame. could you tell me how to do it?
Egemen
(3,383 Views)
guys I have just solved my problem. first I created a control and after it I changed it to constant.
Egemen
(3,382 Views)
Then why did you start a new message thread with the same question?
For reference, the question was originally asked and answered here.
(3,352 Views)
If u got the answer, Mark the Solution..
Silver_Shaper | CLD
(3,345 Views)
I have just marked it.
Egemen
(3,337 Views)
In the previous topic I cannot find any question till the answer of a member named . When I could not find the solution under that topic I decided to write a new one. After a while - after about 5 hours- wrote the answer under the previous topic and I marked it as a solution and I wrote a message under the new topic(that one). Maybe you are right I could not think about embeeding the link of the previous topic (you linked it as "here" above) to the new one and marking it a solution but if you look at the date and time you can clearly understand what it is. Thank you all again.
Egemen
(3,336 Views)
Yes.  Darin gave you the answer to your question 5 hours after you asked it in that thread.
But you waited another 19 hours after that (which I saw by looking at the dates and times) to ask the same question again even though Darin already gave you the answer.  No reason to start a new thread.
(3,318 Views)
