!!!help!!! synchronization camera and measurements
I am doing something similar to Dan and want to synchronize data and video. I tried to find the example you spoke of ("AVI read write with Data Example") that showed how to add data to .avi video frames, but I was not able to find it.  I checked in my versions of Labview (Labview 8 evaluation version, and Labview 7) and on the NI website. Do you know anywhere else I could find this example? Is there Anyone I should contact?
Thank you for your help,
Haji
Message 11 of 14
(1,128 Views)
try LabVIEW\examples\Vision\2.function\AVI\
Dan
Message 12 of 14
(1,097 Views)
I have still some problems with my work. I did something like this...bud I am affraid of there is no synchronization...Could anyone see that and in case give me help for better way to synchronization? Another problem is it is very slow, may be because I show the video from USB camera to monitor, but I have question, what is faster and which variant is bigger on disc? IMAQ AVI Write frame or I should save "video" in datalog and then later converse it to *.avi or can I use TDMS? Can I use some synchronization in TDMS? Thanks for your replies.
Message 13 of 14
(1,096 Views)
Hi all,
I am trying to synchronize my daq (NI USB 6211) and image acquisition (Allied Vision GX1050C) on my VI. However, I do not have an RTSI cable with me right now. Is there anyway that I can sync these two acquisitions (triggered at the same time and acquire one data point corresponding to each frame at any instance)?
Thanks for your help!!!
JY
Message 14 of 14
(679 Views)
