help with NI 9751
I am trying to generate signal using NI 9751 module but couldnot figure it out. Could anyone help me with some basic examples?
Message 1 of 13
(9,608 Views)
what's your problem?
Message 2 of 13
(9,566 Views)
I am using NI 9751 with crio9066 for solenoid injector. Then, I have downloded power train control driver for 9751. In order to understand how it works I opened one of the examples provided by ni for this module. And I have no idea what is going on in the front panel and in the block diagram of the example for 9751.
Message 3 of 13
(9,556 Views)
Accepted by VB05
no controler generated on front panle? when you opened the corresponding example? i think the module can control the output voltage and the duty cycle of the pulse. you can find the DAQ (related to your NI9751)controler on program panle.
Message 4 of 13
(9,536 Views)
http://www.ni.com/pdf/manuals/375969a.pdf
refer to above link, hope it is helpful
Message 5 of 13
(9,534 Views)
Message 6 of 13
(9,530 Views)
Thanks for the help, but I already have those manuals, the problem is I am new in Labview FPGA and with NI devices as well.
For example I have attached the screenshot of the front panel, and I have no idea what is what I was just trying by pressing buttons and so on. I do not have a guideline where it could be explained how to operate that front panel.
Message 7 of 13
(9,517 Views)
all right, could you pls give me the program view of the attached front panel? maybe i can explain all of that.
Message 8 of 13
(9,514 Views)
OK give me a sec Ill attach all the screenshots.
Message 9 of 13
(9,512 Views)
I have sent to you a private message. Please check it.
Message 10 of 13
(9,501 Views)
