05-28-2023 08:45 AM
I have problems with formula node
2015 version of labview, my task is to make a fuel pump,
im left on my own to make this since the class im taking is terible
are there any similar finished projects i can take a look at or any suggestions on what to do
please help
05-28-2023 09:41 AM - edited 05-29-2023 04:33 AM
You just need to start with a few basic LabVIEW tutorials. Have a look at the learning resources listed at the top of the forum.
05-28-2023 10:00 AM
Here's a simple draft that drains the tank whenever the pump is on and the level greater zero.
You should be able to add your other requirements, such as money input and cost calculation. For example turn the pump off if you run out of money or run out of fluid.
This is intentionally just a picture. try to implement it and try to understand the reason for every single detail!
It is nowhere complete and just serves as proof of concept for part of your problem.
