hi, dear friends
i have string starts with #456 then some values and i want to remove #456 and using the other values
how can i do that?
thanks in advance
(3,435 Views)
Make an array containing string values.Then you can use index array function and remove the particular one from the respective index.
look at programs>>Arrays in function pallete.
NB:Also, please give an informative heading to your post about the content inside.
Thanks as kudos only:)
(3,432 Views)
You can use the match pattern function wich would do the job just fine.
Rodéric L
Certified LabVIEW Architect
(3,421 Views)
Accepted by oiuuhjoi
how can i do that?
thanks in advance
If you are always going to have the #456 at the beginning or if it is always going to be four characters then you could use the string subset.
Tim
GHSP
(3,410 Views)
Make an array? Based on what criteria? Your suggestion makes no sense whatsoever.
(3,402 Views)
You are welcome.
Tim
GHSP
(3,379 Views)
