hi, i try to collect a reading/data from various type of pressure transducers,and encorder as my counter using my labview programming. can anybody suggest what card compatible for my application.
i use labview 6, my os is window98. i try to get data from my various type of pressure sensors, encorder, air mass flow meter. i don't now what type of card suit my application.
(2,772 Views)
Any multifunction DAQ card should suit your application. all of NIs multifunction DAQ cards have analog inputs/outputs, digital input/output and counters. Which board would be most appropriate would depend on the specs that you need. If you do not need to sample very fast you could use a Low-Cost E series board like a 6023e.
(2,772 Views)
Thanks for replying. how about if i'm using different product of daq card. can you explain on how to communicate between the labview prog and the card (example of programming/diagram will be good). Please coz i'm a new kid on the block.
(2,772 Views)
can you see if you have all the controls,
precisely the data i/o acquisition controls
if i open an example, it shows these controls, but if i create a new project, it doesn't show all controls
thanks for any answers or comments
(2,772 Views)
I have a similar question as I need to acquire various data including possibly 3 or 4 frequency measurements from hydraulic flow turbines which have frequencies up to 3khz.
Is it simpler just to purchase a frequency to voltage converter and obtain all inputs as voltage signals? Do NI supply these converters?
(2,772 Views)
