hi. please i need your help!!!!
hi. please i need your help!!!! produced , prime, double,odd, single, two dijit numbers create subvi and write txt file
(3,364 Views)
I have absolutely no clue what you are trying to say.  How about typing out your requirements in actual sentences.  And be as precise as possible.
(3,357 Views)
six 1D arrays write to txt file
(3,333 Views)
How do you want the data formated in the test file?  Are all of these arrays of the same data type?  If so, just use Build Array to combine them into a 2D array and use Write To Spreadsheet File.
(3,322 Views)
Accepted by topic author arvin25
Hi arvin,
this is not the explanation we expected from you…
But I removed some of your Rubegoldberg code and implemented a solution to your problem:
Use the free online courses to learn about shift registers, array handling, conditional output tunnels - and try to avoid local variables and RACE CONDITIONS!
Also learn about polymorphism. And why did you use InRangeAndCoerce in one place (left loop) and not in the other (right loop)?
(3,315 Views)
Didn't trust it to work more than once?  This has to be an assignment right?
(3,260 Views)
