hilbert on time domain signal
I am acquiring data at a rate of 30000 samples/sec from an accelerometer, this data is then converted into time domain by using build waveform function, but i am unable to perform hilbert transform on this data, the array returns no values. how to resolve this problem
(2,872 Views)
With some limitations (for the DC and Nyquist components), the Hilbert transform is nothing more than a 90 degree phase shift.
I have not found a Hilbert transform that works directly on waveforms, just on 1D arrays. Since it will not change any other waveform attributes, you might want to do the Hilbert transform before building the waveform or use the attached code (image).
It seems to work with any size waveforms I tried.
If this does not solve your problem, please describe in more detail how you are transforming, maybe attach some sample code.
(2,872 Views)
