marker
I'm acquiring ECG data with labview program.I want to put some markers on top of the waveform chart.I want to indicate all the cases such as resting state ,running state by the help of these labeled markers.I want that when resume is pressed recording will continue from the point where it last stopped and marker labeled for example'resting' will automatically come up.
Thanks in advance for your help"
(2,806 Views)
I responded to your other post explaining how to use markers. Did this
work? If not, please be more specific as to what you are trying and
what isn't working.
Greg McKaskle
(2,806 Views)
