histogram from spreadsheet
Hi, I'm using LabView Express not very frequently - but it sometimes comes handy to use it as a tool for data analysis. I went through the code samples but could not find anything close to what I need: I want to plot a histogram of integer values stored in a spreadsheet file. Data is organized in 3 blank-separated columns and the values of interest are located in the 3rd column:
12221 223 49
17737 342 46
32332 443 38
I would appreciate if anyone could point me in the right direction.
Thanks, Martin
Message 1 of 13
(6,689 Views)
There should be a few examples listed in the NI Example Finder select the search tab then search for histogram.
Have a look at them and post back if you still can't work out what to to. Include your data file and any vi attempts to far.
cheers
David
Message 2 of 13
(6,687 Views)
Do you have the spc toolkit?? It has some histogram charts in it.
Message 3 of 13
(6,674 Views)
Use the Create Histogram Express VI in Mathematics -> Probability and Statistics.  Not a big fan of the express VI but this one works very nice!
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 4 of 13
(6,663 Views)
Hi David,
Thanks for your help! Got the big picture from the examples I found but got stuck at the beginning: I used the Read from Spreadsheet vi but can not extract the column I want. My last attempt is attached as well as a file with sample data. Just need an extra push to extract the last column into an array, I guess from there I can manage creating the histogram.
Thanks for any hints!
Martin
Message 5 of 13
(6,650 Views)
No, unfortunately I don't.
Message 6 of 13
(6,647 Views)
The delimiter must be s simple space character [ ], not the sequence of three characters [" "]. These three characters never occur in your data file! 🙂
Message 7 of 13
(6,642 Views)
If your data for the histogram is integer and has a limited range, I prefer a simple binning operation where you basically count the occurences of each value.
The histogram VIs are more useful to analyze floating point numbers or values that cover a huge range where it makes sense to pool ranges of numbers into bins.
Attached is a simple modification of your VI that finds the frequency of each occurence of the values in the third column. Seems to work just fine. (LabVIEW 7.0). 😄
Message Edited by altenbach on 04-08-2006 09:48 AM
Message 8 of 13
(6,637 Views)
That's exactly what I was looking for! Now I can add some stat functions and I'm all set. Thank you very much for your help - you made my day!
Message 9 of 13
(6,625 Views)
Since I am trying to work out how to extract one column from a spreadsheet I thought I would use this thread rather than starting a new one - although I think I will have a .
One part of my programming in labview at the moment is to write a data acquisition set up (which I have talked about in another thread).  In my data acquisition the plan is to collect 100000 data points with a time spicing of 5 milliseconds.  So with my DAQ vi the plan is toto getdata that has header info and then two columns of data, one column will have the time information (at the moment I want to keep the time information there for future reference in the raw data) and the second column will have the count dat.  The count data is what I want to use in my histogram (I think I will probably need to ask some histogram vi related questions at another time), but I can't seem to work out exactly how to do this.  I use an array subset to remove the header data and then I have used delete from array (although I also tried to use the arrary subset again) to try and remove the time data, but it doesn't work.
So basically want I want to get is just the count data point by themselves which I can then put into the histogram vi.
Any help in working this out would be appreaciated.
I have attached the vi I have put together (you can ignore the histgram parts for the moment as entirely worked out what is happening with that) - this vi is called histogram binning.avi
I have also attached the data file I am testing this on (the count data is currently sourced from  one of the random number generators) - this file is called uniform random with xmin - 1 and xmax - 4000 with header info.txt
I am using LV 8.6.1
Message 10 of 13
(5,864 Views)
