record sound using bluetooth headset
hi
I am new in labview but i need to ask how to record a sound on labview from th mic of a  bluetooth headset connected to the laptop?
Thank you
(3,202 Views)
Hi houda mat...,
it should be possible with the audio functions. You bluetooth headset should be available as a normal device. Connect the correct deviceId and you should be able to receive the sound.
Mike
(3,192 Views)
