how I can programmatically changing symbols item of tree control
Hi Experter
I want change symbols item like a show green box when the judgment is pass and show red box when the judgement is failed.
Please find the picture for what I want to do as attached.
Is there any way to do that ?
BR
Bee
(1,030 Views)
Hi Bee,
Something like this?
Notes:
 - The images must be 16*16 pixels for the best rendering, otherwise LabVIEW resizes them.
 - I also tried to load PNGs instead of JPGs, but then transparency is reduced to either 100% opaque or 100% transparent.
 - I used GIMP to generate the images.
Raphaël.
(1,006 Views)
Hi Raphaël
Thank you for your suggestion, that is what I want to do.
But I cannot open your example on LV 2019
Can you convert to LV 2019 ?
BR
Bee
(974 Views)
Hi Bee,
Sorry I forgot that.
The best is to always provide your LV version in the original post for others to know in which version to save.
Raphaël.
(901 Views)
Hi Raphaël
Thank you very much for your help.
Bee
(846 Views)
Hi Bee,
I am glad that helped, don't forget to "Accept as Solution" the comment that solved your issue:
Also, Kudos are the primary way of saying "thanks" on the forum, the secondary of course being saying "thanks" literally.
Raphaël.
(826 Views)
