Add attributes to existing XML elements in XML-File
I would like to "flatten" existing XML-Files with many "TestStep"-entries, from "old" to "new", by incorporating the Child-Entries "Attr" as an attribute into the normal entries.
old:
<TestReport
  <TestExecution
     <TestSteps>
        <TestStep measid="0220_0005" status="Passed">
              <Attr name="Infotext [Out]" type="String" value="[Request] 22 E0 68"/>
              <Attr name="Requirements" type="String" value="HighVariant" />
        </TestStep>
    <TestExecution
<TestReport
new:
<TestReport
  <TestExecution
     <TestSteps>
        <TestStep measid="0220_0005" status="Passed" Infotext="[Request] 22 E0 68" Requirements="HighVariant" />
        </TestStep>
    <TestExecution
<TestReport
I tried many approaches, but whenever i try to append an created "attribute" into an existing node LabView gives me an error.
Can anyone give me a hint?
This Code gives me Errorcode "-2607"
(4,920 Views)
Here the VI (LV 2017) - but it does not work as mentioned above 🙂
(4,919 Views)
Accepted by topic author Jo__Ho
Hi Jo,
Use method "Set Attribute" from class "Element":
What you were trying to do may not work because XML attributes are unordered.
Raphaël.
(4,901 Views)
Hi Raphaël,
thank you so much for your extremly fast reply!
Your VI i worked perfectly - this is exactly what i needed!
I would have never come to the idea to use "force Type" -  i didn't even know that it existed 🙂
(4,843 Views)
Hi Raphaël,
Like Jo said - this coerce trick is great!  How did you create the Element Refnum?
David
(3,255 Views)
Hi David,
Coerce XML Reference to Element Class.gifCoerce XML Reference to Element Class.gif
Raphaël.
(3,241 Views)
Thanks! Fast and awsome 🙂
(3,235 Views)
