Add attributes to existing XML elements in XML-File
I would like to "flatten" existing XML-Files with many "TestStep"-entries, from "old" to "new", by incorporating the Child-Entries "Attr" as an attribute into the normal entries.
old:
<TestReport
  <TestExecution
     <TestSteps>
        <TestStep measid="0220_0005" status="Passed">
              <Attr name="Infotext [Out]" type="String" value="[Request] 22 E0 68"/>
              <Attr name="Requirements" type="String" value="HighVariant" />
        </TestStep>
    <TestExecution
<TestReport
new:
<TestReport
  <TestExecution
     <TestSteps>
        <TestStep measid="0220_0005" status="Passed" Infotext="[Request] 22 E0 68" Requirements="HighVariant" />
        </TestStep>
    <TestExecution
<TestReport
I tried many approaches, but whenever i try to append an created "attribute" into an existing node LabView gives me an error.
Can anyone give me a hint?
This Code gives me Errorcode "-2607"
(4,314 Views)
Here the VI (LV 2017) - but it does not work as mentioned above 🙂
(4,313 Views)
Accepted by topic author Jo__Ho
Hi Jo,
Use method "Set Attribute" from class "Element":
What you were trying to do may not work because XML attributes are unordered.
Raphaël.
(4,295 Views)
Hi Raphaël,
thank you so much for your extremly fast reply!
Your VI i worked perfectly - this is exactly what i needed!
I would have never come to the idea to use "force Type" -  i didn't even know that it existed 🙂
(4,237 Views)
Hi Raphaël,
Like Jo said - this coerce trick is great!  How did you create the Element Refnum?
David
(2,649 Views)
Hi David,
Raphaël.
(2,635 Views)
Thanks! Fast and awsome 🙂
(2,629 Views)
