how add blocks to programming functions?
Hi
I downloaded LabSQL folder involve some blocks and examples. do you know how can i add them to programming functions like attached picture?
Best Regards
Message 1 of 8
(4,603 Views)
Accepted by behzad1
Add the folder containing those VIs to the user.lib folder in your LabVIEW installation.
Message 2 of 8
(4,591 Views)
thank you natasftw
I did it. but how can I find blocks in programing functions(attached picture)?
Best Regards
Message 3 of 8
(4,583 Views)
Accepted by behzad1
Close LabVIEW and open it again.
Message 4 of 8
(4,577 Views)
thanks a lot. it add to user library but help of block dosnt work. should i add it to another root?
Best Regards
Message 5 of 8
(4,559 Views)
What do you mean by "help of block"?
Is that what you expect to see when you hit Ctrl+H?  If so, that should be part of the VI itself.  You shouldn't need to do anything extra.  If it's something else, I'm not sure what you mean.  Can you explain?
Message 6 of 8
(4,515 Views)
natasftw
Yes, I mean help by hit Ctrl+H  or by right click on the object and select help. but, when I right click on the object, help selection is not active unlike other objec(please check the attached picture).
there is a file name ADO210 in the LABSQL folder(that I download it)  with .CHM format. I thought this should be add in a root to activate help selection. is it correct?
Best Regards
Message 7 of 8
(4,472 Views)
You mix up two things here. The help visible when hitting ctrl-H is directly taken from the VI itself. It shows the VI icon, its connections and (if the VI programmer took the time to fill in VI Description) the text of that VI Description.
The Help in the context menu launches the external help viewer with a help file that the VI programmer must have created and accordingly configured in the VI Properties under Help Path.
Most VI libraries in the wild do not come with such a help file and accordingly no configuration to link to that help file.
Rolf Kalbermatter  My Blog
Message 8 of 8
(4,449 Views)
