how can I control application
Hi
I have quastion
My manager gave me application which is built in software but not labview , he has asked me to control this application using labview , please is there is anyone know which function I should use and how ??
Please waiting your replay:womansad:
(3,782 Views)
That totally depends on the other application. Does it have an ActiveX interface or some other api?
(3,768 Views)
yea , it is have active intervase , it is called IPVC 3
(3,763 Views)
Then you will need the documentation on that from the vendor. You will use it's properties and methods for interfacing. You can get a general idea of how ActiveX is used by looking at the Excel examples but since each ActiveX interface is different, you will have to work out the details yourself.
(3,755 Views)
you mean I should contact the person who designed this program so I can use its proprites to control it using Labview???
(3,752 Views)
Yes
(3,746 Views)
(3,744 Views)
