adding picture to control knob
Hi, I want to display the angle of rotation of a test subject's head as it is rotated slowly by my robotic manipulator.  I could use any number of dials to do this but I would prefer to have a simple graphic of a head rotate around a centre point with the actual position.  Is there any way to put such a graphic on a dial so it rotates with the dail?  Or can I adjust some attribute of a photo to rotate the photo on the front panel with the position data?
I have three axis and feel this would be the best way to present the data to the operator.
Jeff
(2,773 Views)
Interesting idea. It can be done, but it's a bit of work. Take a look at this article and some of the links that are within it.
Making a custom dial.
It would be nice if LabVIEW could rotate graphics on a dial, but it's not a simple thing to do.
     Rob
(2,762 Views)
You might also want to look into 3D Sensor Mapping.  Here is a great link to a tutorial.
http://labview.ni.com/docs/proposals/8.6/Insight%20in%20LV/index.html
https://decibel.ni.com/content/docs/DOC-2059
Jacob K
Jacob K
(2,738 Views)
