hi ya-hoo,
Try deleting the template path and leaving a blank field. The vi is calling for a file that does not exist, but if you leave the template file path blank, the "New Report.vi" should open a blank excel sheet without any problems. Otherwise, you need to create the template file and path, which you have already discovered.
Hope this helps.
