how can I flush the UNDO buffer?
When I run a vi from within the Labview environment I would like Labview to flush the UNDO buffer so that hitting CTL:Z will not have any effect. Can I do it programmetically? Right now it seems to flush it when the vi is saved.
(3,034 Views)
Maybe there is a way to use a filtering event for "key down?", then discard if ctrl-Z is pressed?
(3,034 Views)
I think the LV acts on the event first than passes on the event information to the vi. So even if I read the event info , I would guess that, the UNDO has already happened.
(3,034 Views)
No, this is not true. I just made a quick prototype to show that the ctrl-Z can be capured before it causes the undo action.
This is the point of a "filtering event"!
(3,034 Views)
Another way to disable CTL-Z when a VI is running is to remove it from the menu. You can copy either the default or minimal menu, copy it to the custom, and then delete Undo from under Edit. Might as well delete Redo at the same time. With either the custom menu or trapping it with an event however, Undo will be active when the VI is stopped.
(3,034 Views)
Thanks. Yes it works.
(3,034 Views)
