how can I make a boolean button (t/f) clear a waveform chart
I am plotting a signal that I have sampled using a waveform Chart. When I reset my application using the reset button, I need to reset the waveform chart as well. Is there a setting for this? Does any have a trick to doing it?
(3,519 Views)
Have the boolean write an empty array to the Chart.Look at the Chart examples for specifics
(3,519 Views)
It won't do just to clear the data points. I am trying to make this act as a "reset" option. I need it to clear the data points, and reset the charting at time zero
(3,519 Views)
The example file "How to clear chart & graphs.vi" in Labview do reset the chart x-axis to 0.
(3,519 Views)
Hi
Use a property node.
1. right click on the chart and goto create>>property node
2. right click on the property node and goto properties>>history data
3. right click on the property node and select "change to write"
4. right click on the property node and goto "create constant".This will create the "empty" array.
Wire this property so, that it's called when you click your reset button. This will clear the chart and set the initial time to 0.
Hope this helps
Luca
Luca
(3,519 Views)
