Hi
Use a property node.
1. right click on the chart and goto create>>property node
2. right click on the property node and goto properties>>history data
3. right click on the property node and select "change to write"
4. right click on the property node and goto "create constant".This will create the "empty" array.
Wire this property so, that it's called when you click your reset button. This will clear the chart and set the initial time to 0.
Hope this helps
Luca
Luca
