how can I make the VI to detect the Digital Input from scb 68
i m using the pxi 6704 and scb 68 but can't make it to detect the device. also it works in the MAX.
but when i build up the VI. it can't find the virtual physical channel. can anyone tell me whYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY.? and tell me wat to dooooooooooooooooooooooooooooooooooooooooooooo.
thanks
(2,565 Views)
Hello Jcal,
You need to create virtual channels before they can show up in LabVIEW. Eventhough your board shows up in MAX, there has to be Traditional virtual channels under the Data Neighborhood section of MAX. To create virtual channels, right-click on Data Neighborhood, select Create New, select Traditional NI-DAQ virtual channel and follow the prompt to create one for your board.
(2,536 Views)
