how can I send a file to the printer dirctly out of LabView?
I want to print a .txt file directly out of LabView. Is this possible?
(2,948 Views)
Yes it is posible. The VI attached will print the selected file with your default printer ... Of course you have the posibility to add a control and change it.
Hope it helps you.
(2,943 Views)
Thank your very much for the vi. Unfortunately I do not find the "easy text report.vi" on my system. Is it part of an add-on toolkit or free available ?
(2,936 Views)
You should find it in "Report Generation" from the function panel. (LabView 7.1.) ;?)
(2,926 Views)
