how can I stabilize the DAQ output to four decimal places
I have a daq 6009. I sent a optical signal. DAQ provides a output which varies in 3rd  decimal place. I done averaging all using a program which I'am attaching with this. So can you please help me in this regard
(3,295 Views)
If you take a look at the 6009 specification, http://www.ni.com/pdf/manuals/371303m.pdf  you’ll see that the analogue output is 12 bits, at 5 volts range the smallest theoretical resolution will be 0.00125v. Then when you take a look at the Absolute accuracy you’ll see that it’s typically 7 mV.
If your looking for 4 decimal places of accuracy you will have to look for a higher spec. device.
(3,264 Views)
so through programs we can't make it much stabler than now can you please sent some help such that the DAQ will be stable . Please reply
(3,245 Views)
I’m afraid I don’t know enough details to recommend a suitable card. If you take a look at the available DAQ cards in ‘Products and Services’ you can check the specifications online. You could also contact your local NI sales for advice.
(3,226 Views)
answer not matches with my question .Please read the question?
(3,219 Views)
You need to find a DAQ with a lower Absolute Accuracy.
Also, looking at the spec, you can get a better accuracy with a Differential measurement than you can with a RSE.  Apparently the RSE only works in the +-10V range.  By changing to a differential, you can get down to a +-1V range.  That will help your resolution a little bit.  Just wire the ground to the - terminals on the DAQ.
Another issue could be noise in the system.
(3,214 Views)
