how can I use a microsoft (for example) steering wheel and pedals within LabVIEW (using usb port) ?
I would like to use a regular steering wheel and pedals (game controller) in LabVIEW.
They use USB port.
Is it possible ?
How can i do it ?
(3,104 Views)
In LabVIEW 7, there are some built-in VIs for accessing a joystick. I would think they would also work with a wheel and pedals as long as it identifies itself as a joystick device, though I have not tried this.
You'll find them in the 'Advanced>Input Device Control' palette.
If you don't have LabVIEW 7, I know I've seen some VIs that can access a joystick, but I can't find them right now. Try doing a web search on "joystick +labview" and see what you come up with.
Good luck
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,104 Views)
In case of previos versions of Labview for windows platforms you can look for an example here
(3,104 Views)
Tkank you all.
I knew that one, but I do not know if it will work with a steering wheel & pedals..
Before purchasing the steering, I wanted to make sure that is was possible to communicate (with that dll, or with labVIEW 7's new features for joystick).
Did someone tried it ?
(3,104 Views)
Ok, I've asked my nephew to try LV 7 built-in functions for joystick with his steering will - and it approves that all works well.
(3,104 Views)
Thank you !!
(3,104 Views)
