how can I write VISA in labview to communicate with instrument using RS485
my instrument has a Modbus communication procotol, how can I use VISA write or read to communicate with the instrument? Thanks!
(2,771 Views)
RS485 is simply a physical-layer protocol defining pinouts, signal levels and the like. To make the connection you need either an RS232-RS485 converter (check with BlackBox) or an RS485 serial IO card (check with NI). Either way, there should be no changes required to you Modbus drivers or other software.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,771 Views)
You may need to set the transceiver mode of the IO card - which is done either in the control panel or via an IOCTL/VISA call (depending on the manf of the card).
(2,771 Views)
