11-17-2011 08:35 AM
hallo,i have video about 5 minutes and i want to change it into photos with labview,can you please help me?
Solved! Go to Solution.
11-18-2011 02:06 AM
If it is an .avi and you have the Vision Development Module installed you can sepparate the images.
Christian
11-21-2011 06:36 AM
thank u very much,it is an .avi,do u mean vision assistant?
11-21-2011 07:05 AM
Vision Assistant is part of the Vision Development Module and represents a Configuration Environment including Code Generation for Machine Vision Applications.
Separeting Images in AVI files will lead into using some Low-Level VIs. However there are numerous examples for AVIs shipped with LabVIEW.
Christian
