how can i create progress bar in main vi
also how should i apply this for while loop
Message 11 of 45
(5,299 Views)
Hi minakshi,
which while loop are you talking about?
You wanted to display a progress bar. You got examples using a FOR loop as it is most easy when you know the maximum number of iterations to loop will run.
With a WHILE loop the number of iterations is unknown and you need to find your own criteria for calculating the progress bar value!
Message 12 of 45
(5,298 Views)
Hi , use shift registers for For loop and fix a maximum value. when that value exceeds rest that count to Zero. You can watch the progress bar starts from 0 to maximum value
Venugopal
Message 13 of 45
(5,293 Views)
 : thank you so much ...!! i got it
Message 14 of 45
(5,282 Views)
minakshi wrote:  can u plz explain that mathamatical calulations in that loop
I find it easier to just not have the calculations.  Just set the maximum value of the scale of the progress bar to the number of iterations you need minus one.  You then just have to wire up the i terminal directly to the indicator.
Message 15 of 45
(5,272 Views)
Accepted by topic author JUSTBEGINE
Hi minakshi, Thank someone by giving kudos or accept as solution
Venugopal
Message 16 of 45
(5,266 Views)
hey.. thanks for ur perfect solutions..!
now i want to cantenate string to a perticular numberonly iff that perticular number occure.. im attaching my vi here
i tried using case structure but i dont get  the output..what i was expecting.. also i want to count, how many string i get at red string box.
can u help me regarding this
Message 17 of 45
(5,217 Views)
Hi minakshi,
This seems to be quite simple:
IF "particular number" THEN
   concatenate strings
ELSE
use not-concatenated string ENDIF
What are you expecting?
"Red" box? Or "read string" indicator?
Why do you want to count? Your FOR loop iterates 100 times so you get 100 strings! (An empty string is a string too…)
Message 18 of 45
(5,215 Views)
Hi minakshi, What you are really trying to do? and you wired a Zero constant to case structure ,The case structure always executes Zero case , you will get an other case . Which no do want to concatenate strings:use i iteration of the while loop and use equal with the number you need and then wire equal output to case structure it works then. I have made small change in you vi check it out and give me more details about your task so i can help
Venugopal
Message 19 of 45
(5,209 Views)
thanks a lot for responding.
i have to move a handle in semicircular motion like 30, 80, 110, -30,-80,-110. and im designing UI for that handle motion.  that handle has some firmware and it will communicate with labview serially. means though USB port. i have to send command to firmware in the form of string data. thats why im sending string to firmware. and in UI i dont want to type whole commond string. UI should accept 30 and in back end it should fetch complete string related to that move by 30 degree command. im tring to explain as i can.. hope u understand my words.
Message 20 of 45
(5,198 Views)
