how can i create progress bar in main vi
Here i am attaching 2012 vi
Venugopal
Message 31 of 45
(4,039 Views)
modified VI is perfect.. thank you..
now i want to put condition in my code.. like if and only iif i get the XOR output i want to append 2 string after result and 2 before result
Message 32 of 45
(4,019 Views)
Hi minakshi,
Do you just need a LabVIEW beginners course - or do you need to take some generic beginner courses for "programming"?
Why don't you program something like this pseudocode?
IF XOR(input_array)==Expected_Result THEN
  string := ConcatString(prefix, string, suffix)
ELSE
  string := string
ENDIF
Message 33 of 45
(4,015 Views)
I NEED VI NOT TEXT
Message 34 of 45
(4,012 Views)
Hi , were do you get this xor output ? In the read buffer? and what is that output any examples
Venugopal
Message 35 of 45
(4,008 Views)
Hi Minakshi,
I NEED VI NOT TEXT
Then you need to use LabVIEW and program a VI!
When you have problems to implement such simple algoirithms: Hire someone to do this work for you - and pay them!
All you need is a XOR function, a comparison, a case structure and a ConcatString function…
Message 36 of 45
(4,005 Views)
THANKS ONCE  AGAIN VENUGOPAL.!!! it is the task of generating checksum.. it will be a number..randomly im getting 4 numbers and feed it to XOR
Message 37 of 45
(3,997 Views)
Hi minakshi,
you already have seen how to XOR 4 numbers…
Please attach a snippet of your current solution (or at least of the current state of your VI)!
Message 38 of 45
(3,994 Views)
hi GerdW,
can u please tell me , how to get any output values out of the labview control design and simulation loop?
Message 39 of 45
(3,554 Views)
also how to count the number of pulses in simulation loop
Message 40 of 45
(3,552 Views)
