Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how can i create ring buffer on onboard memory of IMAQ card and then transfer it to system memory
fais
Member
10-21-2002
10:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
IMAQ pci 1411
0
Kudos
Message
1
of 2
(2,476 Views)
Reply
Re: how can i create ring buffer on onboard memory of IMAQ card and then transfer it to system memory
Mike H2
Member
10-22-2002
11:56 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you are doing a ring, the memory will automatically be copied over to system memory when you either display or do a copy on the buffer. I would recommend that you set up your ring to copy the memory directly to the system memory.
0
Kudos
Message
2
of 2
(2,476 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
