how can i create ring buffer on onboard memory of IMAQ card and then transfer it to system memory
IMAQ pci 1411
(2,474 Views)
If you are doing a ring, the memory will automatically be copied over to system memory when you either display or do a copy on the buffer. I would recommend that you set up your ring to copy the memory directly to the system memory.
(2,474 Views)
