how can i generate two column excel file in ASC11 format and send it to osclloscope with sampling rate of 204.8
how can i generate two column excel file in ASC11 format and send it to oscilloscope with sampling rate of 204.8. iam using AT-MIO-16XE-50 from National instruments. please one example. thanks
(2,545 Views)
What do the 2 columns represent? Is this one or more analog waveforms that you want to output from the DAQ board? Is there timing information included?
Reading a text file is easy with Read From Spreadsheet File and there are a lot of shipping examples for analog output. Basically, you would create a 2D array and wire that to the scaled data input of AO Write so if you could provide details on how the data in the file is stored, it would help.
(2,545 Views)
yes 2 analog waveforms i want to output from the DAQ board. these analog waveforms i want to superimpose on each other with different amplitude level.data is stored in ASC11 format in the excel 2 columns. thanks for tips.
(2,545 Views)
