how can i give output as a digital signal in labview
I'm trying to give output to a device named as "BNC-2120",as a digital signal using simulate signal as a source.
I'm getting right result on the waveform graph but I'm not getting any output on the oscilloscope (connected to BNC-2120).
please tell if any other information is required.
 I have connected the oscilloscope with labview using  P(0.0)
Thanks.
(1,127 Views)
1. Youre trying to write in two ways in parallel, through DAQmx Write.vi (but without initialization) and throught the DAQ-Assistant. This cannot work and I assume there's some error when doing this.
2. The BNC-2120 is just a connector block for a DAQ-Card (like e.g. a PXI-62xx or USB-63xx). Feel free to share which exact DAQ-Card you are using.
3. To properly output a digital Signal (PWM), go to Help->Find Examples... and use the Digital - Continuous Output.vi Example:
That example works for multiple channels (by writing an Integer that contains the state for all digital outputs in the task), you can simply write a 0 or 1 as integer to set the first channel in the task to high/low. Then insert as many Samples as you need:
E.g an array of 0,0,0,0,1,1,1,1 output at 100hz output rate gives you a 12.5Hz Digital Signal with 50% Dutycycle.
Best,
Jan
(1,110 Views)
you probably need to use the function DIGITAL WFM
(1,084 Views)
What will have to connect in the input of the wfm. As it is not getting connected with Simulate signal or the true-false array or the output of comparator operator.
(1,053 Views)
1. Earlier, I ,tried to use both of them separately also but it didn't work.
2. I'm using the port pxi-6229
3. I'm using LabView 8.6 and don't have that example here.
(1,051 Views)
with this new vi I'm able to get some output.
But.....
I'm getting output as 0(blue channel) when there is a square wave on  "waveform".
and I'm getting 5(blue channel) as the output when at near  100% duty cycle.
Yellow channel is what I'm trying to follow.
thanks
(1,042 Views)
Hi , it's hard to tell what is going on without showing the code.
(1,028 Views)
