how can i make a plot in a 3d graph invisible
hello all,
attached is a half-way completed vi which shows how i would make the plot/plots in the 3d graph invisible. unfortunatly i do not know how "item" can refer to the plot i want to make invisible.
any ideas?
(2,321 Views)
Accepted by topic author labviewette
You are almost correct.
The Item input is a string whose value is the name of the target plot. You can view all the plots names from shortcut menu->"CWGraph3D" group->"Properties" item->"Plots" tab ->"Plots" list.
(2,303 Views)
