how can i put every values of every NCOUNT in a array
I attached the file the number of Block data (NCOUNT) is not constant i want put every value of every NCOUNT in a array
(2,748 Views)
You've asked the same question 19 times. You've gotten answers in both English and French. It seems like you're not reading any of the responses. Why don't you at least have the decency to explain why you're not satisfied with any of the good answers people have given you?
(2,748 Views)
Sorry i didn't ask the same question i thing you have understading the same for all, here i ask the question but i didn't find the answer, with the file attached i can't put all the values of NCOUT in array i mean
1.0000E-06 1.0000E-06 1.1124E-02 1.3940E-03 3.8779E-05........... in array nobody gives me the answer, and please if you can't help nevermindmaybe you dont wantnevermind too, but thank you for all
(2,748 Views)
I posted a VI on one of these questions which placed them all in an array. You just need to just the number of iterations through the for loop and it will read that many lines from the file and place them in a string array. You should still be able to use that for this example. Just make sure that you read in the correct elements of each line in the file.
J.R. Allen
(2,748 Views)
