how can i set mouse cursor location in a vi at a particular control button
If there are many string controls on a vi front panel,I want to set my cursor at a particular string control.
Whenever i will give an input ,It should be typed in that string control only.
How can I do that ?
(3,196 Views)
use key focus property of the required control.......Smiley Happy
LV 8.0, 8.6, 2011,2012,2013 WinXP
(3,192 Views)
Accepted by topic author Kaku
there is a property node which called Key focus, you can use it for the string you want to be enabled.
when you run the vi, the curser goes to the selected string control
check the attached vi.
(3,189 Views)
Thank You !!!!!
(3,173 Views)
nice to help you,
if you like my reply, please add Kudos.
(3,170 Views)
