10-20-2010 09:38 AM
How do I add a 95% confidence ellipse to an XY scatter plot.
10-20-2010 01:20 PM
Just add the ellipse as another plot. The XY graph can accept an array of plots. Please look at the examples that ship with LabVIEW as they show you how to use charts and graphs.
10-20-2010 01:50 PM
I'm sorry, I did not ask the question I intended to. How do you calculate a 95% confidence ellipse to be added to a XY scatter plot?
10-20-2010
03:13 PM
- last edited on
07-09-2024
06:54 PM
by
Content Cleaner
possibly some info towards the bottom of this link.
https://www.ni.com/en/shop/labview/overview-of-curve-fitting-models-and-methods-in-labview.html
Founds this info here. http://ask.metafilter.com/36213/Best-Fit-Ellipse
theta. the numerator should be sumdxdy and the denominator is a subtraction:theta = 0.5 * arctan( 2*sumdxdy / (sumdydy - sumdxdx) )
at the end i will explain what the ellipse means.
recipe 1
- start with two columns
- from those values, calculate the average (
- generate two new columns,
- calculate the following, which are the same as above, but for the new columns:
- calculate the angle
- as before, generate the following from the new columns:
- finally(!) calculate:
recipe 2xandy, which are the coordinates of the points in your scatterplot. from those columns, calculate the following variables:sumx = sum(x)sumy = sum(y)sumxx = sum(x*x)sumyy = sum(y*y)sumxy = sum(x*y)n = number of pointsxbar,ybar) and the variance and covariance:xbar = sumx/nybar = sumy/nvarx = sumxx/nvary = sumyy/ncovarxy = sumxy/ndxanddywhere:
these should be the same scatterplot as before, but shifted to be about the origin.dx = x-xbardy = y-ybarsumdxdx = sum(dx*dx)sumdydy = sum(dy*dy)sumdxdy = sum(dx*dy)theta = 0.5 * arctan(2*sumdxdx / (sumdydy*sumdxdx))which is the angle that the ellipse is "rotated" from the horizontal, and also:c = cos(theta)s = sin(theta)XandY(if you can't use capitals change the names!) which should be the same scatterplot, but with the rotation removed:X = c*dx - s*dyY = s*dx + c*dysumXX = sum(X*X)sumYY = sum(Y*Y)varX = sumXX/nvarY = sumYY/n
these are the lengths of the semi-major and semi-minor axes (the two principal "radii") of the ellipse (which is which depends on your data). the basic ellipse that you want to plot has that size, is centred ona = sqrt(varX)b = sqrt(varY)xbar,ybar, and is rotated by the angletheta. see the explanation below for what this means and how to generate other (larger) ellipses.using just the
xandycolumns, and appropriate formulae above, you can calculate everything using:
explanationvardx = varx - xbar*xbarvardy = vary - ybar*ybarcovardxdy = covarxy - xbar*ybarvarX = c*c*vardx - c*s*covardxdx + s*s*vardyvarY = s*s*vardx + c*s*covardxdy + c*c*vardytraditional statistics often assumes that noisy data is distributed as a "gaussian" or "normal" distribution (this is justified by the famous "central limit theorem" that says you get this distribution when life is complicated). the process above is equivalent to fitting a model for that distribution when it describes two, correlated variables (x and y). the final values
aandbare the "standard deviations" of the underlying, uncorrelated distribution (ie with the rotation removed).section 15 of numerical recipes describes things in more detail (especially section 15.6).
if your data really do follow this distribution then a and b give the relative sizes of your ellipse. you can scale that ellipse to include any given fraction of the distribution.
disclaimer - i am not 100% certain about this next bit: in particular, the usual ellipse plotted is one that contains 68% of the data (it's a convention), which you would get by multiplying a and b by the square root of 2.3 (see the reference above to numerical recipes).
posted by andrew cooke at 6:44 AM on April 14, 2006
