why there is no parallelism inside the While loop like for For loop is given?
Why there is no Parallelism inside the while loop as it has been introduced in the For Loop?
(2,815 Views)
Because with a For Loop, you can determine how many times it will run before it starts executing.  With a while loop you can't.
(2,801 Views)
Concider that a mega-Kudos since "why" question are the hardest.
Ben
(2,796 Views)
Similarly, a Conditional Terminal in a For Loop configured for parallelism will break your code.
(2,787 Views)
