10-30-2008 12:25 PM
I want to reduce the left margin size in my charts. Labview seems to waste a lot of space in the left margin. See attached screenshot. Is there any way of doing this?
Dave
Solved! Go to Solution.
10-30-2008 01:02 PM
You can customize the control by right clicking on the control, going to "Advanced->Customize..."
When the control pops up in a different window you can change from 'customize mode' to 'edit mode' using the wrench/compass button on the toolbar.
In customize mode you can resize the background so it takes up less space.
-Jonathan
10-30-2008 02:34 PM
You don't even have to go through the trouble of customizing the control. Just grab a drag block on the edge of the data display and move it to the left.
10-30-2008 02:42 PM
PaulG. wrote:You don't even have to go through the trouble of customizing the control. Just grab a drag block on the edge of the data display and move it to the left.
Doh! I just assumed that is was more complicated then it sounded, so I went straight for customize control, whoops!
