how do I change range properties for clustered sliders
I've seen many similar questions, but none with satisfactory solutions.
I have a cluster with 80 sliders for a dual monitor status display. I want
to programatically change properties of these sliders on an individual basis.
(i.e. 1st element slider has a range of 0 - 1000, 2nd element is 0-20...
If I access the properties node by using controls[] from the cluster property
node, but I can only access the frist group of properties (blink, value, position etc)
I do not see the data range or slider properties.
How can I access/change these without hardwiring to all 80 sliders?
thank you for any inputs!
(3,276 Views)
You need to type cast the slider references so that they are Slide(strict). I have attached a small vi as an example. I hope this will help.
(3,260 Views)
" … I can only access the first group of properties (blink, value, position etc). I do not see the data range or slider properties."
Use the "To More Specific Class" function (Application Control palette) to typecast the generic control refnums coming from Controls[] to Slider refnums.
Hope I'm not misunderstanding.
Fading out. " ... J. Arthur Rank on gong."
(3,259 Views)
Exactly what I needed. Thank you both so much.
Is this kind of information easily gleaned from NI docs, or is it more of
a windows programming mindset?
thanks again....Craig
(3,242 Views)
Actually, it's a basic principle of object-oriented programming and has nothing to do with windows or LV. You can find a lot of documentation about this in this site and other places. Just search for "classes" or "object oriented".
Here's a link for a nice tutorial which deals with the specific topic which was on this thread.
___________________
Try to take over the world!
(3,219 Views)
