how do I create a maximum or minimum value during continuous acquisition?
Here's an image of the problem I'm having. It's not letting me create a constant on that wire. That is the 1-D array waveform that I'm writing to the file. What seems to be the problem?
Message 21 of 29
(1,729 Views)
As I said just above, attach an actual VI instead if an image.
I can easily create constants on arrays of waveforms. What is your LabVIEW version?
Message 22 of 29
(1,721 Views)
Labview 7.1
Message 23 of 29
(1,717 Views)
Well, LabVIEW 7.1 is ancient. Works just fine in LabVIEW 2012.
Message 24 of 29
(1,715 Views)
Unfortunately, I think this is the only version we have in lab. I will try to see if we can update it. But if not, is there any alternatives that could work as well?
Message 25 of 29
(1,710 Views)
I am sure you can program your way around it. What is the purpose of the constant?
Message 26 of 29
(1,705 Views)
I'm not sure what you mean by constant. I'm still don't quite understand why a constant should be wired there. I completely understand when you said that I'm writing as an array, but am trying to read it as double, and that's where the error lies. I'm just not sure what the constant is for. Again, thank you for taking the time to help me out. I'm brand new to Labview and things are still confusing and I truly appreciate your time.
Message 27 of 29
(1,703 Views)
You tell me - you're the one who mentioned it:
"Here's an image of the problem I'm having. It's not letting me create a constant on that wire. That is the 1-D array waveform that I'm writing to the file. What seems to be the problem?"
Bill
CLD
(Mid-Level minion.)
Message 28 of 29
(1,679 Views)
you can use peak detector for finding maximum and minimum value of contious graph..of any signal.
Message 29 of 29
(1,574 Views)
