how do I export a screenshot of a plot area, all contents?
I have an XY graph in my control panel which has some other controls within its bounds, and I want the program to export an image of the graph, including the controls.
My front panel looks like this:
And I want my export to look like the following when I push the "Screenshot" button:
When I use the waveform's Get Image method, it excludes the other controls:
I thought I would try using an invoke node on the VI's front panel (as described here), and then take a subset of that image using the graph's position/bounds, but the origin of the screenshot depends on how the user has scrolled or resized the window, so that's unreliable. I'm looking for a way to do this that doesn't involve fixing the window size and position.
Any ideas?
(3,586 Views)
Accepted by Artybear
(3,579 Views)
That works great! Sleek too; I thought I was going to have to resort to something hacky. Thanks!
(3,565 Views)
Oops.  That original will only work correctly if the control is in the first pane.
Here's the fixed version.
(3,536 Views)
Hello  pcardinale
Could you please post a PNG image of the VI or LV2009 version of the VI because i have LV2009 I was not able to open the VI.
Kamal Daniel
(3,525 Views)
(3,514 Views)
