how do i know the execution time of my vi?
I want to know,how long my VI is executing.
I tried by going into Tools>Profile>Performance & Memory/Trace Execution.
Is this the only way to find the execution time or is there anyway to find it.
Please let me know.
Rakesh
Message 1 of 13
(4,164 Views)
You can put a msec timer at the front of your VI, one at the end, and subtract the difference and display on an indicator.  This is a good use for a flat sequence structure where the first frame has the time, the middle frame has your real VI, and the final frame as the timer again.
Message 2 of 13
(4,162 Views)
Thanks for your reply.
Can you show me with an example
Message 3 of 13
(4,157 Views)
Message Edited by Ravens Fan on 04-13-2010 08:37 PM
Message 4 of 13
(4,149 Views)
thank you
Message 5 of 13
(4,133 Views)
You can also use the VI I posted here some days ago. It is very easy to use when using the error cluster wire.
Message 6 of 13
(4,110 Views)
thank to all,it helped me alot
Message Edited by raki on 04-16-2010 11:36 PM
Message 7 of 13
(4,068 Views)
the execution time of my design is 1msec- 5msec
i compared the execution time of my design with the similar design whichwas implemented in C. It was 306 msec.
 He used pentium 120 MHz processor
 I am using Core 2 Duo 2 GHz processor
will it depends on the processor speed or does labview has any DSP clock??
Message 8 of 13
(3,973 Views)
Your code is theoretically running about three times as fast if you adjust for the CPU speed and assume both version run on a single core.
Yes fast PC's should run it faster.
Ben
Message 9 of 13
(3,967 Views)
I wouldn't read too much into a speed comparison of LabVIEW on a modern Core2 and C on a old Pentium.  Optimizing your code for best performance on your machine is what is important.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 10 of 13
(3,946 Views)
