how do i measure bipolarforAgilent E3631A ?
Hello, i am new in using labview .
Can any one please help me how to measure bipolar Agilent E3631E ?
My goal is to sweep the output of E3631E voltage supply from -25 to 25 V on the I-V plot. Since I already made the i-v curve from 0 to 25V  or otherwise, but i could not get it sweep from -25 to 25 V
Ti
(2,655 Views)
Your supply has one output for 0 to +25 and another completely separate output for 0 to -25. You could hook up one output and do that plot and then connect the other to do a different plot or append that data to the first plot. I don't know if it's possible to connect both outputs to the same place with one output turned off while you were ramping the voltage of the other output. If the manual doesn't discuss this sort of connection, you might want to check with Agilent.
(2,642 Views)
Hi Ti
if you already have suceed in sweeping from 0 to 25 v
it should not be   a major problem to do the other sweep.
Is your supply floating or grounded !
Remember you have to enable the appropiate supply .
Also your output supply . Set the -25v supply to your negative (ground) connection
and the 25V to your positive supply connection.
If you have further queries don't hesitate.
If need be post a jpg of your working code.
xseadog
(2,633 Views)
