how do i plot with the operating system time in one plot and show lines between cursors in another using the same XY graph?
I am having some trouble graphing two plots at once. One plot is to show the current temperature inside a chamber as a function of time. I am trying to pick the current time and temperature each second and plot it with each point being connected by a line. I am able to show a moving, blinking dot each second but I can't figure out how to develop an actual line with these dots. To make matters worse, the blinking dot is back in the year 1903. I understand that it uses seconds elapsed since 1903, and am trying to find out how to graph the current temperature with the system time.
The second plot is just 5 moveable cursors that are to be connected by a line. I am able to move the cursors and retrieve the position information, but I can't make a line between them.
I have attached my main .vi, though you may have to pick the graphing part off to have it work for you.
(2,960 Views)
You're not creating the XY graph data correctly. I've attached an example with a couple of simple XY Graphs. One is using a couple of shift registers to hold the spearate x and y arrays. I think this is what you were trying to do. The other one uses a VI from the shipping examples called XY Chart. It makes an XY Grpah act like a chart. I've also shown the correct way to display current time.
Message Edited by Dennis Knutson on 05-12-2005 03:51 PM
(2,946 Views)
Dennis,
Thank you for your example. I was unable to run the top graph becuase I do not have the XY Chart Buffer sub vi. Could you post this for me as well?
Much thanks for your help thus far!
(2,934 Views)
Yes, you have it. As I said, it's part of a shipping example called XY Chart. Open the example finder or go to \examples\gneral\graphs\charts.llb.
(2,928 Views)
