how do i set a breakpoint in LV 2011
i was forced to switch from LV 8.5 to 2011. when i right click on a wire i don't see the "set breakpoint" command on the menu.
So...how do i set a breakpoint in 2011 ??
(2,575 Views)
Accepted by jknapp
jknapp,
That selection is still there in LV 2011.  Are you sure that the VI is not setup such that you can not debug it?
Cheers, Matt
(2,574 Views)
