04-03-2007 11:46 PM
04-16-2007 11:23 AM
Joelro79, You need to add this address in the configure screen on the Shared Variable. To get there right click on the variable and select properties, in the bottom of the general tam you will see the option data binding there is where you need to place them. I attached an image.
Best Regards
04-17-2007 10:54 PM
04-17-2007 11:07 PM
Try using the browse button to the variable instead of typing it. You are using double \ in the middle, it should be \\<Computer Name>\Shared Variable\Stop
Best Regards
04-18-2007 10:29 AM
04-20-2007 03:50 PM
